Why are you bleeding brakes have you rebuilt or something,
If it's because of lack of braking there is a small O ring in most master cylinders which acts as a non return if this fails could be your problem.
The brakes have not worked since we got the tractor. The only video i can find on YouTube says one needs to get into the rear axle to find the workings of the wet brakes.
Where do i look for the master cylinder?
Thanks John
We also have a problem with the torque amplifier. The tractor won't move forward unless one takes ones foot of the clutch extremely slowly. Apart from these 2 problems it is a good machine.
Thanks john
Would be worth you posting on farmingforum.co.uk
Thanks john
WWW.GOOGLE.COM
Thanks John
It's what the pedal is connected to / opperates.
