2 hours ago, Jack.P said:
They are typically filled up with grass or hedge cuttings sometimes just leaves then dragged back through the Garden /path  to the trailer then dragged out again when dumping .sometimes prickly stuff like holly will go in there which doesn’t help.I was going to order another 100 this afternoon but trying to find an alternative .as soon as the bag has a sizeable hole then the rubbish just comes out in the clients garden when pulling them .smaller purpose made garden waste bags I have found to be much too small and a waste of time
Have a look at barrow bags, they're about the size of a wheelie bin, and designed to be moved about when full by a sack barrow.
Hi couldn’t you use wheelie bins? Or could you use the hippo bags that B&Q sell. Or the bulk sand / gravel bags the B&Q use .
Good advice.also just noticed out off 2t oil and fuel .aspen not arriving TIL Tuesday .probably stupid question but will I get away with using mower oil in 50:1 mix for tmr only then back on aspen .
Depends what your mower oil is, but basically no if its a 4t oil.
Edited by htb
