Hi all,
First post.
I recently purchased some dried oak firewood from a local supplier, it was discounted due to some mold on the outside of the logs. Since I unpacked it the wife mentioned that burning moldy logs in the wood burner might not be that wise.
Naturally popped that into google, the consensus is that if the logs are seasoned or wet not a good idea. If kilned dried ok.
Thoughts & feedback would be appreciated.
Stu
1 hour ago, Woodworks said:
It's just a bit of mold on the bark. I would not be remotely worried as long as the wood is dry
Yes just put them somewhere dry and airy and they will get below the moisture content that fungi like.
This is  much the same as I have seen from batches that were warmed up in the kiln and then removed before the moisture content had been reduced enough, the warm humid conditions allowed the fungal spores to  germinate and the fuzz is hyphae  spreading.
... though if your worried, pop them over to mine and I will get rid of them for no charge. If you are storing them outsde then not a problem, they coe in, go on the stove and the tove door is shut, the mould won't go anywhere
