Anybody doing day rate processing around Hertford?
I will hopefully be getting 20+tones of processor grade(well to my uneducated eye!) ash, be in about 10ft lengths, to be processed to 9-10 inch logs.
I will be there to assist with loading and clearing split logs. I have a mini digger with a thumb, a couple of trailers to use as log decks if needed and a loader to clear split logs.
Should be a really nice job!
So if anyone is interested and wants to let me know prices that would be great?
Do you have a tractor to run the processor?
Not at the moment.
Looking to hire a fully operated machine really- if I operate the processor I will have to get someone else to operate the loader/digger/saw/broom, so everything, including the processor will be less efficient!
I thing its better all round for me to get an operated machine??
20 minutes ago, william127 said:
Not at the moment.
I can operate the processor, getting it there on a tractor is the problem. Throwing it on a trailer is much easier/cheaper.
Unfortunately no tractor at the moment?
Cheers though.
On 24/06/2019 at 07:06, Duncan. said:
Ollie Berti 07766044989 probably worth a ring should think he'll help you.
Thanks, when the wood is back here I'll get in contact.
  • 7 months later...
We are based in broxbourne area and have a processor if you still need this?
I can also do days chainsawing logs into rings ready for splitting.
07759-245-611
Cheers :)
07759-245-611
Cheers :)
All sorted now thanks, back to the manky arb waste, which I have the kit to handle. Cheers though ?
