https://youtu.be/KlaNWSn-4yI
Some help needed here, the brake tension spring broke on my Stihl 036QS . I’ve replaced it and it all seems to be fitted correctly but now the chainbrake handle is being overpowered by the quick stop. When the usual brake is engaged, the QS still forces the saw to drive the chain , albeit slower as its forcing the clutch to turn whilst on break??
I’m not sure if I’m missing something obvious.
I was tempted to disconnect the QS cable but I’ve since read it’s all or nothing as far as chain brake, one element won’t work without the other ?
PS yes the chain is loose, it’s a carving bar ?
Can anyone send me a workshop manual?
i think I need to see the correct configuration of all the chainbreak elements including the QS parts, so I can compare with my saw .
I’ve taken a vid of it running, please see the link at the beginning of my post.
 Thanks,
Si
Edited by wisewood
I sent you the sm for the 034\036 +QS
you will have to see if you have fitted it correctly, the bits you need ie handle and chain break of the QS are in the sm.
other than this this I can’t help any more. I'm the sort of person that has to see it then follow the sm step by step
edit: let me know if I sent the sm correctly and if it helps you fix it.
as it just may help others in you shoes at a later date ?
Edited by Wedgebanger
Edit
  On 21/06/2019 at 20:08, peatff said:
I haven't seen one of those it's a new one on me. Is there any adjustment on the cable ?
Expand
Possibly, wedgebanger sent me the service manual so will be studying very closely ?
Expand
Many thanks for this mate,
only had a quick skim through so far but yes the sm looks to be all there ?
i shall update my post once I’ve sorted it or sent to spud lol
Read more
