3 hours ago, Haironyourchest said:
You could also use a cheap kago drill on hammer setting with a spade bit sharpened to a cutting edge?
 Would the drill 'hammer' into wood??
I thought it had to be a proper hard surface to work right.
I welded a 4" brick bolster to a pinch bar but an old boss used a spade bit on a pinch, just buff it off with a grinder when u need too.
I found the brick bolster to be better as thinner metal than spade bit.
It works really well in a tight hole, axe far better in a wide hole
