Gutted, just in the last week or so, something has been in stripping bark off a few of the willow slips that were planted over winter.
Is this work of the deer, or something else?
There's the odd roe deer in the area, didn't think they were frequent. Can live with the odd leaf being nibbled but not this vandalism!
Thanks, didn't know that. :icon14:
It's not like there isn't hundreds of other mature trees (or fenceposts) to rub against :ph34r:
Have strung up a length of barrier netting to try and keep them away from the willows for now
You will find deer will also strip rings of bark away in order to get moisture from the tree get a salt block and hang it from a mature tree it will run down the bark and the deer will love it and stay away from your willows
It looks identical to the fraying our resident roe buck does, which is also done to mark territory at this time of year.
You could try inserting some other sticks in the ground to distract him but you may find the only solution is fencing or freezing...
Not sure if the barrier fencing will work, infact might just become a hazard to the deer if they carry on fraying their antlers.
But the time for fraying could be almost over as most roe should be in hard antler shortly.
U might get a small amount of fraying in 4 to 8 weeks time when bucks marking territories for the rut (breeding season)
Often with territorial marking u often see a wee triangle off scrapped ground below the tree too.
In the past when u had more forest rangers controlling deer they would actually leave the large bucks near vulnerable young tree crops, as they will hold a larger area and keep many small bucks away. Small bucks cause far more damage as often more of them competing showing off against each other.
Modern deer management tends to be more about purely numbers so very few good mature bucks are left as a 'stand' buck
Deer tend to always fray on smaller trees rather than mature 1s andd tend to favour willow, some old school foresters would plant sacrificial willow purely fort the deer to fray/mark
Nic I've never heard of roe or fallow ring barking trees, but reds definitely will. Some will also bore score the trees too ( usually red, sola and occasionally fallow
My roe deer loved the aspen and spindle, haven't done so much damage to the willow. I had to send one of them a 150gr invitation to quit but generally I like seeing them around, especially now my woodland is better established.
That willow will probably survive, although I might be tempted to put rabbit spirals around it
