Made up a set of dolly wheels for front of CS100. They've been a great help. Obviously a lot easier to wheel about even though they dont steer. But the biggest plus point i wanted to share is how easy it is to push up 8ft skids. So much so i've decided not to bother fitting a winch. When having to balance on the rear wheels i found it impossible, and always working alone it was a right pain. . Speeded things up no end. Well worth knocking some up.
Wheels were £12.50 from ebay. Foam filled. Steel, had anyway. Total time was a couple of hours.
No more setting and hauling with pulleys. Pretty sure 6ft skid wouldn't be much harder.
Not sure why pic is on the side.
Those wheels are the nuts, got sick to death of my drag about yard tool box having permanently flat tyre and fitted the same, never been a problem since.
Bob
1C679E3D-1CCC-44EC-8C97-8C597992EE72_zps
Thats a great idea.
I had a sack truck with normal wheels and they used to only last  a year. Replaced with these so got two exta as been meaning to make the dolly for a while. Also got foam filled on my arb trolley but they were £30ea with bearings
You got a link ?, to save me looking at all the others.
Cheers
The foam tyres are good but the bearings are rubbish, they don't last long on a sack truck with heavy use. You can get replacement bearings for a couple quid but they don't last any longer.
The good wheels are the magliner ones, but you need deep pockets.
Yeah these are good for the job on the dolly. On my sack truck ii used to move round full 45 gallon drums occasionally. Never had a bearing go though. Time after the inner tube had failed.
