Hi. I have been getting a few logs slabed up since getting the new double headed mill.
I have been asked by a few clients to process some of there felled trees.
the biggest problem i have is getting my timber dry fast enough, for myself and clients.
I have a large (1.2m diameter, 5m long) spalted beach a customer would like milling and turning into a table. can beach at 3" thick be put straight into a kiln?
on this matter i know oak and i beleive cherry are difficult to dry fast, i have the following timbers also cut and would like everyone opinion of how long to leave before putting in the kiln so as not to get massive case hardening problems (or any other really bad shakes and warps) at 2 and 3 inch thicknesses. I will be using a humidification kiln not heat vent.
sweet chestnut
monkey puzzle
cedar
ash
yew
9 minutes ago, Big J said:
Beach - sandy thing, usually next to water
Beech - tree-like thing, often confused with the aforementioned sandy thing
Anyway, you can't force dry sawn timber like firewood. It's marketability and usefulness to the customer is dependent on it's quality. Rapid drying (excluding vacuum kilning, which operates on a different set of rules) results in defective timber.
Beech air dries rapidly compared to most hardwoods. 3 inch, stacked in a well-aired barn, shielded from the rain will get close to 20% by autumn. At that point, you can consider kilning it.
Do not put it into the kiln before that as it will twist heroically. Beech has a reputation for that. Even in an air drying stack, make sure it has a lot of weight on top of it. Tonnes, not kilos.
legend, thanks Big J
spalted beech should have a bit less of a tendency to warp as some structural degradation has already taken place amongst the cells where spalting has occurred but it will still dry fast enough.
any reason as to why it can't be milled slightly thinner for even faster drying? 3" will take a while longer than 2-2 1/4"
Yep, because that is what the customer wants!!!!!
I agree, if a single slab table 1.2m wide and 4.2m long is 2inch thick it will look thin enough. And cupping might take it down from 3 to 2 by the time it is flattened
theres a good chance that the centre of that  trunk could be soft and squidge, cut and milled enough beech to recognise the signs
I cut big slabs at 3-6" thickness, depending on species and grain.
2" thick is often not enough cohesion when your board weighs 250kg+
Literally it might break under its own weight.
[emoji106]
