  • Replies 79
David,
Can you post some pictures of how you mounted your reverser? I am stuck on this part of the process. Any specific details would be great as well. That looks like a nice design. Also, how far from the front axle are your lift tabs/implements?
Thanks,
ACUF
David,
Thanks,
ACUF
mybox is defferent from yours. dose yours mount on the ring of bolts round the imput shaft? mine is just 2 M14 bolts in the side so easy to bolt down
i dont know for sure but id think it will be about 5' from the front axle to the ends of the lift arms. shorter the better tho. you'd be better making it to fit Catagory 2 mounts
can you take off the ram and mount a chipper straight onto the lugs david and miss out the arms to bring it in closer and keep the weight off the front a bit.
thats what id like to do but its getting the shaft to work when its close coupled that i cant work out. it wound make getting the woodchip into the box a lot easyer too, think it needs to fly 7' just to reach the box :001_smile:
This is helpful. Thanks. The mounting of the reverser is very specific. How did you make sure the alignment was spot on?
I am worried about a slight misalignment, and causing future problems. What are the catergory 2 specs? I believe my CH140HF is set for both cat 1 & 2 configurations. But, in terms of making the top links mounting bracket off the Schmidt lift, I need to decide the best placement, etc.
Any more pics of U900 and reversers would be helpful.
Thank you!!
ACUF
i already have enough big chippers.:biggrin:what else you got??:001_smile:
6x4 mog and the wee forklift (oh fixed the starter) not that you need any big boys toys now :001_smile:
