Hi -
I've got a Husqvarna 61 - old but still doing good service - the oil cap is split beyond repair. My saw has the alloy fuel tank - all of the caps I have found state ' not for alloy oil tank ' . Has anyone by any chance got a serviceable used one they would be prepared to sell ?
Thanks.
Is this because it seals with a washer on the face rather than an O ring on the edge?
I have one but I'm not sure which saw, can you measure the diameter? The washer is a bit perished.
Edited by openspaceman
Depends on the age of the saw, the very early 61 had a small breather cap part no 501564101, this also fitted the early 162, this cap is no longer available, the later cap 501626601 ( black) is far bigger, 501626602 is the same cap in grey, all 61s had an alloy crankcase.
Thanks to all  for prompt postings offering info - appreciated.
to : Openspaceman ( thanks very much for image etc you provided )  - yes - it does seal on the face ( there is a narrow machined band on the tank body where the seal sits)  - the dia is 1"  /  25 mm give or take a fraction .  Cheers.
Okay then what I have must be a fuel cap for a 162 or 280 as it measure 36mm across the outer diameter.
28 minutes ago, Rough Lumber said:
Sorry I meant to say that the 1"/ 25 mm is across the threads .
36mm across outer 30mm across thread on mine.
I'll try and remember to search shed tomorrow but I think I disposed of all the 162s
