3 hours ago, AJStrees said:
Very nice. I've got a load of alder, well probably 30 sticks that could do well at making floor boards or cladding, when I ever get a bandsaw. Those boards look real good though.
As you know it’s not rated at all well for rot resistance if left wet (unless under water). Lovely to use though - light and easy to dry and cut.
That’s true but I’m sure they will be great for floorboards. Can’t see them getting too wet in a bedroom. Unless you’ve got a water bed.
What I haven’t told Mrs Ed is that Alder apparently used to be used as sacrificial woodworm bait - leave a bit of it around and they will choose that. Not sure if that can be true really but it’s a good joke if nothing else.
Pimped up my eco mill a bit with a new handle and rubber grips on the cross handle. Hope to try it out tomoz.
Nice one. I find my eco mill benefited from some comfort refinements.
I have used pipe insulation on the long handle. i’ve actually removed the upright handle because I didn’t use it as much. Ive also added a few jubilee clips to keep the long handle in position, it kept moving with the supplied screws.
Milled some oak last weekend.
12 minutes ago, AJStrees said:
Milled up some beech rounds on an old stump. Rather nice colours.
You might want to seal those asap or they will split once they start drying.
