If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
Boggle4137
Hi everyone, I recently did a job for some guy at his home. He wanted me to completely remove his four stumps (that where all fused together, approx 3ft X 2ft in area) and loads of exposed roots. I told him he's better off getting someone with a stump grinder in and probably a landscaper so a proper job gets done. He then said he was keen for me to take out as much as possible, basically he wants it done on the cheap....
So, I went to go see my grandad for advice, he suggested take out as much of the stumps as possible and cut/drill a series of holes in the stump and load them with rock salt, wet and rub it all in then cover with a tarp to keep dry until it breaks down. I googled this and there are tutorials but not much info on if it actually works.
Anyway my question is how likely is it to work? I was carefull to make sure the salt only went in/on the stump and it's been completely covered. Not sure on species and the tree was cut around 2-3 years ago. Any advice or results are welcome and criticism of course.
15 answers to this question
Register a new accountSign in
