If your Rotatech chains are anything like the ones I have had you wont be wanting to touch the depth gauges/rakers for a while as they come out the bag set very aggressively. As said a fraction here or there we make diddly squat difference.
Ah ha , I remember fag papers, used to set the points on my Herald with those. cant remember which was which but I think green pack was thicker than blue pack or visa versa.
You have be a certain age to know what I am on about.
Rizla ! Green , Red and Blue . ?
9 minutes ago, EricBradley said:
Still wont make any difference but it is actually 30 thou difference not 3 thou
No it isnt.
Depth is typically 0.025" (and not 0.25" as mentioned above). T'would be some scary contraption to rip a 1/4 inch cut per tooth.....
52 minutes ago, bmp01 said:
No it isnt.
But that is not what the op put, the difference in his figures is 30 thou.
.025 - .022 = .003 . That's three thousands of an inch .
The OP quite obviously got his decimal point in the wrong place . If you had a raker depth of a 1/4" you would have no raker at all !
Edited by Stubby
I think your maths is skewed  the difference twixt 22/25 is three thou
Hi folks, Just to settle the argument, I got the decimal point in the wrong place in my original posting.
it should have read 0.022" and 0.025" making the difference between the 3 thou or B----r all worth worrying about it seems.
Phew ! ?
