On 17/12/2018 at 18:12, Steve Bullman said:
Not sure how long ago this guy got stuck in the cavity ?
What was the result of the testing on this? Is doing the testing fairly simple once you have the kit?
I recommended a little out of the top. All the upright regrowth around the crown was forming a secondary crown with the center stem poking above it by around 4 meters. Bit of weight out to help reduce the chance of failure. Also some of the heave over extended laterals to have a slight weight reduction.
The testing is reasonably simple after you have got used to it. There are a lot of individual steps in the process, so long as they are all done properly everythings ok.
Thanks Steve. I plan to get some testing done with some of our veteran/notable trees on the estate I work on. Money permitting of course. But I believe it will help with any trees that might be on their downward spiral finding them before it is too late.
What area? Get in touch if I can be of assistance
  • 1 month later...
Picus test in Straford St Mary for a Dedham Vale Tree Surgeon this week. Lovely Copper Beech tree in a very prominent position. Tree was deadwooded, very lightly pruned and then inspected. 2 pretty large cavities were of particular concern and I was able to poke a probe in one and out the other, so a picus test was carried out to assess the extent of the decay.
Turns out it was a lot better than expected but still in a pretty compromising position.
Picus test results
What age did you anticipate the tree to be Steve? And as for still being in a ‘compromising’ situation, what life expectancy do you give the tree according to your findings.
I find this technology quite fascinating and intriguing.
