This sounds a bit like the question about employers liability insurance, when two self employed people get together do you need EL? In that case the person responsible for the contract with the customer is held to be an employer even if some of the people on the job are self employed.
Edited by Dan Maynard
finger trouble
10 hours ago, Treewolf said:
This may be a question that everyone else knows the answer to, but I don't....
If you are a freelance self employed climber, is the provision of appropriate rescue arrangements down to you (as you are your own employer)  or the outfit you are contracted to?
Both!
You can have 5 climbers on a job but real world incident 4 of those could flap and go into shock upon a real world incident where a rescue is required and the 5th could be bleeding out.
You can be as trained as you like and refreshed every 6 months but when needed I guarantee you things won’t go down as per risk assessment.
If you climb solo know your limitations, if your in a gang your only as good as the guys beneath you, cut small think twice, don’t try to be fast and stay safe.
Your employer has a duty of care over employees and is legally obliged to provide a rescue climber.
Real world,not all do and even those that do provide a groundie with a rescue ticket,some of em havent climbed regular so would be of no use in a worst case scenario.
I've been considering an ART twinline for the reasons some have gone into above (sadly I'm waiting for cash flow to improve to get one - plus the extra rope).
The concept seems a good one to me - get two lines in as part of the same process and you automatically have a rescue line (or spare line) taking you to the main climber's TIP.
Anyone used one?
PS yes you'd still need a rescue climber but getting them up there would be quicker to the extent of making the rescue climber exactly that rather than a paperwork exercise perhaps?
Edited by Puffingbilly413
Anyone used one?
Why not just have an extra rope and throw it over a good TIP? You don’t need the fancy stuff, climb how your comfy and put a second line in the old fashioned way. If that’s your thing, real world you’ll get pissed off with installing and de installing a second line.
Yep - that's a fair point Wes.  I just like the idea of installing two lines from the ground at the same time.  And I do like stuff - perhaps that's the problem!
I suppose I should add - the reason I replied here was that my thinking was if there is a complete system that works which will give people an 'automatic' rescue route from the off (ie the employer provides it, trains it etc) then that's got to be a good thing. Plus if it's there from the off then you don't need to install/re-install?
I see where your coming from but again real world, UK trees, just climb the tree and stop over thinking. I get installing from the floor on absolutely massive trees however let’s be honest 90% of the time a ladder and a climb is quicker and easier than installing from the ground plus once you have your TIP you can easily throw a rope over another crotch for rescue.
I suppose what I meant was that virtually nobody (ok - some) has a competent (v quailfied) rescuer if i follow the thread correctly.  So we're either happy to take the risk or we're not. I think most seem happy to take the chance on the person on the ground sorting them out on paper and getting themselves out in reality.
But I'd still like to know if anyone had any feedback on the twinline...
Wes - yes I do overthink.  Always have done!
