Any tank that has fluid drawn from it needs a vent to allow air to replace the fluids removed. The MS200T oil tank vent is under the upper nylon chain buffer on top of the bar mount. You will need to remove the buffer, remove the oil cap and get a bit of pressure from something like an air line on the vent and a bit of WD40 or carb cleaner to shift any issue.
I was close at least. ;)
Hi Spud
Just for clarity do you mean some pressure to the vent from inside the oil tank or from the outside, under the chain buffer?
Cheers
These vents tend to get plugged. They only operate one way so you need to use an airline on the outside of the vent to blow any shyte that could be blocking it inwards in to the tank. You can use a soft pipe over the vent to see if it is allowing air in to the tank but sealing under vacuum.
  • 3 weeks later...
Emptying the tank of oil and rinsing with some sort of solvent or petrol solves many  non-oiling problems! does anyone else find that chain oil can become a bit jelly-like after a while in the tank?
Also, more modern saws seem to be really sensitive to what chain oil you use! I have a MS201T-CM in which I use Stihl Synthplus oil - very runny. The saw runs like a dream and I have the flow set right on the E mark. At work I use an identical saw but the oil we use is a more traditional style, thick, stringy stuff. We've had no end of problems with saws non-oiling and have to have the flow on full blast just to get anything down the bar!
