Stihl FS410c Clutch issue?
smokingdragon
Guys
Started my FS for the first time for a few months and found that the blade rotated when I pulled the cord and the blade no longer stops when idling, The beast has had hardly any work and up tp now has always been reliable. I ran it and strimmed a load of brambles and knotweed today so it still functions but its defintely not right!
Any ideas? My thoughts is that its the clutch stuck on?
Cheers
Simon
Edited by smokingdragon
spelling
You have a bit of rust in your clutch....that's clutch not crutch which is something completely different. You will need to strip it down and strip the clutch, clean off the clutch, apply a bit of grease or copper slip and reassemble. Be OK for a good while then.
