Hi folks
Looking for suggestions of tools/machines/techniques for reducing a large spruce stump and surface roots.
This is for myself so any notion of profit etc doesn't matter!
I need to take the height down a good bit so I can put a hardcore track over it. If it ends up sinking slightly at this spot in 20 years I'm not fussed.
I don't own a stump grinder, I would consider buying one, but not sure the current finances would get something that was much good? (1-2k?)
The obvious first step is dig, clean, and cut with chainsaw.
I have a small mini digger (Kubota k008)  - I vaguely remember someone on here posting a photo of a knife/bucket for shaving away at stumps?
Unfortunately there is a soil pipe to the septic tank somewhere underneath so can't go crazy trying to rip the thing out
Is a Terrasaur blade any good?  https://www.orbitalfasteners.co.uk/en/products/300mm-x-20mm-terrasaur-carbide-blade-premier-diamond-products-dp16740
Open to any ideas!
Best bet would be stump grinder, but if you have time on you side clean it up best you can even jet wash it then hatch a Chris cross pattern in it 2/3 inch squares and pull bits off with digger with ditching bucket.
