Evening all just after a bit of advice I have a hedge cutter that fires up no problem then after about 3 mins just keeps cutting out. Then leave it a few mins then starts up again. I have had the spark plug out and air filter. Any ideas what it could be?
Check the tank vent is not blocked . Try running it with the fuel cap slightly open . If it keeps going then its likely the tank vent is blocked .
after its cooled and started again does it run all day or just for another 3 mins? Is it a HS45? Mine had an issue like this and it was the coil on its way out. As soon as it stops, pull the plug and see if its sparking.
Evening no it just cuts out again and again going to have a good look at it when I get chance
  • 3 weeks later...
Hi all, hedge cutter still doing it, ajusted carb, check fuel filter.
