I have two small trees quite close to an overhead electricity wire which need felling, Scottish Borders. Does anyone have a contact I can call for the utility company to discuss switching the supply off while tree work is done?
Thanks for that Tom. I'll try to get through to the right person for a steer on the way forward. The trees could be dropped in minutes but they are leaning heavily right over the wire. Not touching it yet but definitely going that way.
Contact the dno and they should instruct the contractor for that area and raise a reactive job. If they are close they will sodt it for you. After all they are obliged under th E.s.q.c.r regs.
