Looks like he’s sharpening the flat of the blade rather than the bevel.
would have to take off blades to do bevel (on most small/medium disc chippers anyway.) Would be handy for touching up in between proper  sharpenings.
very similar to a dremmel motor?
  • 1 year later...
That is the idea, to put an angle or bevel on the back(flat) side of the knife
We do a blade grinder for our Disc Blades, it would be fairly easy to mackle up a slide etc for flat blades. You just got to understand that precision and not overheating blades is key!
Choice of abrasive is key to not overheating. What does your grinder use?
Not sure but we purposely use an underpowered grinder, you cannot overheat the blades as the motor stalls out ahead of that kind of abuse!
