4 hours ago, wicklamulla said:
@Billhook   What do you use the frame work for that is attached to the front of the Stiga?
It was built so my wife could carry garden tools when the arb trolley was not hitched, but mainly to take the wheelie bin down our long drive to the road which was quite an effort uphill on the way back!
We have tried to find a narrow and wide wheel which would interchange on the same axle and we cant find it. On ours we offer a bolt on axle so you have to swap the axle with the wheels - works fine only takes 4 bolts.
Out of the two, if I could live with the extra width, I would take the wide wheels every time. Its surprising how much weight you can pile on these little carts/trolleys and the wide wheels just travel so much nicer over all terrains.
Will the axle fit the stein?
I have never actually seen a Stein trolley in the flesh so I can only guess, but looking at pictures, it looks like it wouldnt be that easy to have an interchangeable axle as it is integral to the structure. Having said that, anything is possible if you try hard enough !
Do not see why you need to change the axle.  The wheels on my Arbtrolley are only held on by quick release lynch pins or R pins and I am sure that a couple of these offset wider ones would fit but I have never felt the need so far.
https://www.ebay.co.uk/itm/260mm-10-Sack-Truck-Pneumatic-Wheel-pair-offset-hub-trolley-wheel/372214307643?hash=item56a9b39b3b:g:i~0AAOSwLUpaeFzy
