  • Replies 22
Mine did exactly the same thing. It started to fray and break where it contacted the unit so I just made it shorter and it still worked perfectly. Though now the wires going a second time I will need to replace it as there wont be enough left if i shorten it to get that springy action.
Edited by treediver
The wire is there so that if you are 200ft up a cliff and need to switch it to a different rope by removing the nut you don`t drop it. For tree stuff its not essential. Just take it off. It doesn`t affect the function or safety.
who trained you 2 b a loler inspector? prehaps you should ask them whether or not they effect the function or safety
It most certianly IS esential, please don't pay 2 much attention to the abouve post:thumbdown: not only am i a very experianced loler inspector but i work quite closely with ISC & I can assure you on Wayne's behalf that without the wire SPRING it is not safe & would not have obtained its PPE CE mark!
I've replaced mine twice, and yes it is a spring to operate the cam and so is important.
I found the best replacement was some sheathed stuff that you can buy off the roll in the larger B+Q stores.:001_smile:
what caused it to fray? i do see a fair few which need replacing but it usually lasts a year or 2 minimum, people do catch them as they tug their saw up whilst their strop is hanging, maythis be what happened?i will do some experimans 2 c if an extra layer of shrink tube will help to make it harder wearing without effecting the functionality & may relay youre concerns 2 ISC next time i chat 2 them, mind you,the vast majority of people have no complaints
the company i work for buys alot of the ropegrabs and when it comes to the sixmonthlys, most of them end up with a partially or completely severed wire. seems to be somewhat of a design issue when they are subject to very high levels of wear and tear. id say most of the lads i work with use em but i dont personally. not keen on em.
I replace my wire on my grab with wire, slightly thicker,that I get from BnQ, of course, doing this is a modification of a product/device, that is CE marked so should not really be done.:sneaky2:
