Lathe Upgrade
flames
- yeah the wheels are castors with a ratchet jack foot in the centre - to make it easy to move about as my workshop space in limited, they work very nicely.
Outboard; I should be able to turn a cylinder diameter 700mm x 700mm long, big enough. ?
Really nice looking machine (and platter, btw).  Have you made it variable speed?
That sounds scary.  Should be a good test for the castors!
Edit:
I looked at the facebook pics - very impressive work.  The outboard rig looks awesome.
Did you have to machine a new spindle for it?  Good opportunity for a more standard thread pitch, I suppose, but that must have been so much work.
Not sure about the colour.  Couldn't you source any pink?
Edited by onetruth
Edit:
Thanks, yes I run it from a Teco inverter - awesome bit of kit. Castors are 1/4 or 1/2 tonne capacity, so should be a problem for big stuff.
Yes made a new spindle, there should be some pics of that in the FB album. I dislike standard threaded spindle noses, as you can only turn one direction, which I find very restrictive. The chucks are direct mounted, so are solidly connected to the spindle and can not unscrew.
Colour is anthracite - partners favorite, brownie points earned :-)
Cheers
