Evening Folks , has anyone attempted to repair or Rebuild a Track or Final drive motor on a mini digger  .
My Kobelco has decided to spew the Drive  making Hell of a racket, sounds like the half shaft stripping.
Drive motor is off and on bench at the moment, have removed the  pump and there is needle bearings floating about too !
Looking fairly terminal at moment and have priced a New unit up @ £1400 .?
Ste
Edited by IVECOKID
We have a few Big Hydraulic outlets here but they won't touch Track motors , I have Phoned  half dozen Specialists  up and the  cheapest is £1400 up to 2k .
My Kobelco is only a 2 ton machine .
Ste
Just now, sjs5060 said:
Try m j lavin on the Wirral, I'm sure Martin will fix you up.
ste
Hi , that name has been thrown in the hat by a fitter I know  , I will give him a ring ?
Thanks
Ste
Only a 20 min drive away too
Thanks
Ste
6 minutes ago, arboriculturist said:
Regularly change the oil and the final drives would outlast the machine - don't, and you know the rest.
Same goes for your truck diff.
I have regularly changed oil but Seals went and soil entered, my fault I should of got seals done straight away , machine is 18 years old but very clean for its age .I have owned it for 10 years .
Ste
Edited by IVECOKID
2 hours ago, Khriss said:
£1400 !! Try Euro hydraulics Leeds - godsake - it must be gold plated ! K
Unfortunately not- my dads case digger had a new track motor costing that kind of money.
i haven’t the know how to rebuild myself so not much help to the OP
