Dolmar 420sc problem & various questions
I think the oil pump is knackered on my 420sc as its stopped oiling. Tried various things read on forums etc to unblock it but not luck.
Anyone dismantled one to acess the oil pump, from reading the repair manual seems pretty complicated?
Maybe it didn't like veg oil. I have being using it  for  about 3 yrs with veg oil.
Also is the makita  ea4300f the exact  same saw in blue as the  dolmar 420sc?
Repair manual link:
https://www.manualslib.com/manual/834167/Makita-Dcs3500.html?page=2#manual
  Quote
Note: Always use a new circlip 4
(927.408.000)!
Expand
Why the need for new circlips?
Yeah they don’t usualy pack up on these saws and it’s very difficult to get the repair kits now  the new oil pump is approx £30-£33+VAt part number
Is 161346-0  they are the same saw as the makita ea4300
its not too difficult to do the pumps in these it can get a bit messy after using veg oil in behind the clutch and drum
its always good practice too put a new 99p circlip on after removing it a couple of times once they become weak,  they’ll come off and get lost
Thanks shavey
Iv'e found some parts cheap on a  different model saw, but they look the same in diagram & *OIL PUMP ADJUSTMENT SET PS32 thing is only £1.20. plus P&P
http://www.powertoolspares.com/tool/makita/spares-and-accessories-for-ea3201s/ea3201s/spares/
Worth a punt?
Oil pump complete is listed  fitting for both models here:
https://www.kettensaegen-saegeketten.de/8782/oelpumpe-fuer-dolmar-motorsaege-ps-32-ps-35-ps-350-ps-420-ps-460-ps-500-ps-6100...-auch-fuer-makita-dcs-3500-dcs-3501-dcs-4300-dcs-4301...
So is that the bit that  may normally need replacing?
Something to be sure of....Check to see if the worm drive driven by the clutch and the drive on the pump spindle is ok and actually being turned .
Edited by Sawchip
Hi can't get the clutch off with pliers. Looks like I might need to try make my own a tool or buy the special dolmar tool. Tool is about 35 euro
Length of plate with 3 screws?
Google it. If it's outboard you can stuff starter cord on the spark plug hole and knock it with a brass drift. Will be opposite thread to normal.
Maybe you already tried? Stick a pick up
Read more
