Our Iveco tipper broke off. Rust-tastic. What do we think? Worth fixing? Truck is pretty old and tatty but a good work horse...
What should we expect to pay for it to be welded back together?
See pics
  On 23/11/2017 at 15:20, dan494 said:
ouch. did the mot not pick that up?
Expand
Ours didn't before ours did the same previously
Not too difficult a fix, grafting in new rails and attaching the hinge. We repaired it ourself over a day or two, but I would think it would be fairly pricy to get someone to do it, which is a shame if it's other- wise decent motor.
I would get a quote, then weigh up the cost, downtime etc against a newer vehicle. But if buying s/h there's lots of unknowns, so you may buy more issues.
We ran that particular vehicle for another three yrs without a tipping problem and it's only currently off road due to an injector/fuel pump problem.
See pics
Expand
Way better than ours, which broke both and body fell off, bending the ram mounts:$
£200, £300 depending how much works involved in grafting new steel in to weld the pivot points to
could be cheaper/ easier to just get a new body if can find one. Know someone whos body was on its way out and got a reconditioned tipper body for about £800 fitted if i remember right
Read more
