This is an interesting but slightly worrying thread. I've only discovered the Caritools in the last couple of years. Until now I was pretty impressed with them. Though had concerns about snagging issues.
So I've got a couple on my harness, one of which I use to hang my tree saw on, 200t.
All you guys that have had them fail on you, what has been hanging off them at the time? I mean am I in danger of the saw plummeting to earth?!
I have the 200t on a tear-away strop which means I can hang it long or short on my harness. I think I'll attach the end of it to a conventional metal krab and just use the Caritool to hang it short from now on just in case.
Obviously I could upgrade to the 15kg rated bigger version which ought be more than strong enough but I really don't fancy the increased snag risk. Especially in light of Matty's scary story.
Def fix it onto your tool attachment then to caritool for short attachment
As above, they're not a main attachment point.
Always worth remembering about using tearaway lanyards as well, especially when tying on big saws with the rear handle.
Better off trashing a big saw if it gets stuck in the kerf than getting ripped out the tree.
Na, although don't do that obviously.
Just that some attachment points are bloody strong. I've been pulled off a stem before when a 44 stuck in a chog and nothing gave way till the chog fell off, luckily, by which time I was upside down.
I was using a piece of climbing rope as a lanyard because I liked having a rope grab on it for adjustment.
