Hi All
My Jensen A530 doesn't seem to be pulling in the brush as well as it used to I've changed the knives and adjusted the spring but it's still a little reluctant
Do I need to run a grinder over the rollers and do I need to remove them to do this? Any other ideas would be appreciated
it you want to use a grinder its rollers out time, top roller easy enough and lifts out when you undo the wire holding it down, bottom is alot more involved
I beg to differ, we touched up a Greenmech with a dremmel to instant effect, did them in situ.
1 hour ago, Woodee said:
Hi All
The springs and roller bearing are supposed to be changed every 500 hours, we have just done ours at a cost of roughly £180 and the difference is staggering. We also gave the top roller a grind when it was out and the bottom roller a touch up with the dremmel in situ.
Dremel maybe, haven't tried one, angle grinder I have, couldn't get the right angle while on the chipper, need to come out really
