Im wondering about vented bag sizes and suppliers . Essentially im after being asked to supply a shop with bulk bags of hardwood . They have sold firewood with a degree of success before and they were describing bags around 1.4 - 1.5 m high with a plan area of 0.9m x 0.9 m from memory .
Has anyone ever come across bags like these ?
1 hour ago, SbTVF said:
Can you not decant logs from a solid vessel so you can quote by a definite volume rather than per bag. Doesn’t matter if they’re stretched then.
I suppose you could but id say the emphasis will be on appearance , as in if you put the theoretical correct volume in and its still a bit below the top people will imagine theyre not getting full value .
Just say product may be partial to settling out?
Certainly Wood sell a tall 1.6 cube bag that sounds like it might fit the bill.
As a slight aside how is your customer going to handle the aforsaid filled bags,  they will weight 500 kg or more each.
A
