  • Replies 21
I have one of those adjustable ones Steve.  Works fine.  Used them quite a bit in the past.  My only problem is finding a pole for it.  I left the poles in England thinking I had used them a lot in Norway and they would be readily available.  The people advertising them don't have them in stock so I have to order online.
Thats the one mate.
I also need to get a polesaw blade for the extendable pole then I will be good to go.  I prefer that one as you can adjust the head somewhat to get a better angle on the pruning cut.
2 hours ago, Steve Bullman said:
Anyone know where I can get one, or if they have been discontinued?  I can only find anvil blades online like this one
https://www.worldofwolf.co.uk/categories/multi-change-tools/product/wolf-garten-multi-change-adjustable-anvil-tree-lopper/RCVM~RCVM#general
I've been using that for years Steve and never had a problem with the cutting.  I guess you foresee issues such as the blade not cutting all the way through perhaps?  Not an issue in my experience.
It does make a big difference getting the twig/branch right into the throat of the cutter because of mechanics but that will have applied equally to your bypass version, which I never knew existed.
Jon
