  • 2 months later...
I have the exact same trimmer rob, with the plastic blade guard still on. Head has got 3 large cracks in it and I only bought it 6 weeks ago. First crack appeared after 2 hours use. Going back to stihl.
On ‎12‎/‎09‎/‎2017 at 09:38, Burgess said:
The newer magnesium echo gearboxes aren't as bulletproof as the old all steel ones (the LW is the magnesium ones) but still very good and a very nice finish.
Is that the new HD "Heavy Duty" gearbox?
Thing I like about the Echo is having the sharp blade tips, it'll saw through stuff that won't fit between the blades.  They always seem to cut better than the Stihl's imo.
I haven't used the heavy duty one either, I was told a few months ago that they were bringing out a new heavy duty gearbox. If I understand the HD has the sharpened blade tips like the old HCA-2400 had.
We recently bought the Echo polewith HD gearbox.
The cutting teeth are not as long as the rear handle Stihl which I would suggest is why it is not so easy to cut the really thick material. They are a tiny bit shorter than the Stihl pole.
This is clearly a design which is engineered to protect the gears. Fitted 6 gearboxes to the Stihl even though greased after each fuul days cutting.
Echo excellent on coniferous hedges.
