NEW NPTC assessment schedules
bob
Just a heads up the new assessment schedules are on nptc website
as i understand it anyone registering before the 1st of jan can have either the old or the new assessment
After the first of jan i believe they will all be to the new assessment schedules
Some have changed quite a lot and some just a little bit
Chainsaw and Related Operations (QCF) November 2009
CS30 - Prepare and Maintain the Chainsaw
CS31 - Fell and Process Small Trees
CS32 - Fell and Process Trees Over 380mm
CS33 - Specialist Tree Felling
CS34 - Sever Individually Uprooted Trees
CS35 - Sever Multiple Windblown Trees Including Leaning Half Blown, Broken Trees and Hung Up Trees
CS38 - Climb Trees and Perform Aerial Rescue
CS39 - Use of a Chainsaw From a Rope and Harness
CS40 - Carry Out Pruning Operations
CS41 - Undertake Sectional Felling Operations
CS42 - Carry Out Stump Protection Using Stump Protection Fluids
CS43 - Fell Utility Poles
CS45 - Aboricultural Ground-Worker
CS46 - Re-pollard Trees at a Maximum Height of Five Metres
CS47 - Safe Use of a Chainsaw from Mobile Elevated Work Platforms
CS48 - Use of Powered Pole Pruners
CS50 - Techniques For Dealing With Damaged Trees
http://www.nptc.org.uk/assessment-schedules/
Edited by bob
some interesting reading there Bob
Ie cs 30 1.2 must be held prior to cs31 assessment so long double day assessments then
Assessor must make kit check prior to use ! ........
Cs50 mmmm
not sure what you mean
you had to have all 30 to do 31 previously
