As the title says my a540 roller speed adjustment has stopped working, it's just set at one speed which ever way I twist the dial, any ideas anyone? Not had this happen before. Thanks for any help
Is your hydraulic fluid up to the level ? Are the connections to the solenoid good . Is the solenoid fecked possibly ? All I can offer I'm afraid .
Sent from my E8QP using Arbtalk mobile app
Thought it could be the solenoid, it has a red light on it if they means anything? Also what does the little brass nob do next to it? I'm new to Jensens and it all looks a little foreign 😂
The brass nob should be wound fully out.
There's a small valve inside the speed control unit if you take it off you might be able to loosen it with a small flat headed screwdriver
As in the electric box down near the engine? Sorry for sounding so stupid I only know timberwolfs!
No just inside the dial that you turn to adjust the roller speed . Take that off with a spanner and the screw is inside .
I'll have a look tom, what does the screw actually do behind the dial?
