Which tracked chippers will fit in an 8ft box trailer
Kinghawko
I used to fit a jensen 530 into an for 8x5 cage side plant trailer, it was a tight fit, you'd need to measure carefully before purchasing.
But did the hopper hang over the front?
I think the forst is slightly shorter than the jensen at about 2700mm but that hangs over the front of an 8x4 trailer. Incidently a gm safetrak 1920 fits in an 8x4 trailer with the hopper over the front but as the tracks stretch you can't quite shut the back, similarly as the leg slides wear the track scuffs the sides.
No that was fitted in. It was touching the back ramp though.
