We had a stream flood this week that got two foot high in one of our sheds.... I had one of my stihls on a low shelf and it was completely underwater.... what would be the best thing to do? I'm sure it has silt all over in it
Sent from my E6782L using Arbtalk mobile app
check the old threads, as some other people had similer incidents, take off the exhaust and see if there is silt in there if there is, you will need to take the top end off and clean the top of the piston and be try to turn it slowly, to prevent hydraulic lock.
best bring/ask spudulike
Hi i droped a saw in the river last year took about 2 hours to fish out as i couldent see it ,took spark plug out and removed fuel and oil caps and air filter then put saw onto galvanised shed roof upside down for about a week in the hot weather the tin radiaded heat into saw . re fuiled and new plug and filter started 3 rd pull not had and problems with saw since.
