Will that not make the rope fail its loler tho?
I wouldn't fail a rope for having that on it. Others may disagree.,,,
Timon.
the hole in end of rope sounds like a good idea. Will definitely try that.
Have considered the choker joker but will still have problems when I use a pulley. Not keen on running rope over a caribiner.
If a loler inspector fails your rope for that then I'd be looking for a new inspector.
Ive done exactly what Ewan has mentioned on some of my ropes.
You can buy a little XRSE carabineer which you can push through the centre of the rope and it will act like a little retrieval ball. Or, most simply of all, just clove hitch the ball to the bitter end of the rope!!
Horses for courses. All work!!
Is it a bad idea to run a rope through a carabiner? Or is it just a personal thing?
Timon.
I Agree with Timon. I have seen this done over a number of years. There is no need to fail as it is just for retrieving. Just make the loop small enough so you can't put a normal karabiner in it.
Martyn
Just that the carabiner wouldn't provide same friction benefits as a pulley. Would be no better than just using a conventional ring cambium saver. Also, not sure about what how it might wear on the rope by running it over a single crab.
Meanwhile...
So i decided to by a PulleySaver and have put a small hole in end of my rope and tied some old throwline cord into a small loop through the hole. Now i can just hitch my retrieval ball to the loop and away I go.
Cheers for the suggestions chaps.
  • 3 weeks later...
