I was given some joinery offcuts by someone who wanted to know if they would turn ok. I decided to try a goblet as I thought the dimensions of the starting blank suited it.
I'm happy with the result although the bottom is still rough. I haven't oiled it yet
Image it was loosely based on
Sent from my iPhone using Tapatalk
Ah thanks steve I'd never have known.
The more I look at it the more I wish I'd made the bead a smaller diameter like on the glass. But once I had a reasonably even shape I bottled going any further. I'd probably have cocked it up and not had enough left to correct at that point haha
No no . That an improvement over the glass . Much more stable so you wont spill your mead !
Thanks stubby. Now I just need some mead haha
Any suggestions on a suitable finish. I normally use danish
danis will be fine just use lots of coats.
i would like to say that iroko is not the best wood for a goblet if you intend to drink out of it as it could leach out a few tastes that probably won't help the flavour of your drink.
