Moving on from my last post.....Has anyone had experience of painting over galvanised steel? I have some estate fencing that has been galved (about 2yrs ago so well weathered) and needs to be painted black. Any recommendations of products and preparation greatly appreciated.
Cheers CP
Painting galv is the same as anything else, except you get best results with an etch primer, particularly when its electro plate.
A quick rub over to take off any grime then paint with etch primer
Tor Coatings in Birtley used to make an excellent solvent-based primer for galvanised surfaces which doesn't need an etch primer. I used it on my galvanised land rover chassis with no degradation ~6yrs later. They never advertised it so you would have to ring and see if they still do it (my can of it has no codes on).
The advantage is that it's black, so it overcoats easily with a coat of tractor enamel for a long-lasting finish.
Alec
edit: found it - it was always difficult to locate as it wasn't listed properly, see here:
http://www.decoratingdirect.co.uk/viewprod/t/TORGALVPF/
Edited by agg221
Alec
Alec
Many thanks, great advice as usual!
That looks like just the ticket, and free delivery too👍
Craig
Thx guys some good advice there, it's been up 2yrs so hoping it's weathered enough. Will degrease and steam clean it first👍
Craig
If you can't wait a year,what you should do first is apply a coat of mordant solution before painting
http://britanniapaints.co.uk/wp-content/uploads/pdfs/Roofs/Mordant_Solution.pdf
Easy enough to get hold off .
I support what Remora107 says - had a new Land Rover chassis, left it 12 months(don't ask:001_rolleyes:) washed it off with Mordant solution and then just primed and top coated it black as normal. Its cheap, easy to apply, and just hose off, leaves a blackish colour as well before painting. Paint is still good after 3 years - better than a new puma 12 months old! cos I'm sure they used a water based emulsion in the factory:confused1:
Hi pressure wash it down, let it dry and give a coat of quick drying metal primer then 2 coats of metal shield black paint. hope this helps
ps ex RM
use ordinary metal primer and go back in a years time and watch it all peel off
use the proper galvanised primer or your in trouble it will peel
some good advise has already been given
