Chipper blades. Co.uk
gdh
I think you've pressed or filled the circle that says "collect in person" (bottom left)
I thought that but it was already selected. It looks like there should be other options. I tried again with 100 blades to check it wasn't a cost thing but it didn't work. I'll contact them later.
From my recent experiences with them I would look elsewhere.
They totally screwed up an order for stumpy teeth and
others I know have had blades re-ground at the wrong angle, then 'corrected' to a different wrong angle so there was no room for any more grinding!
This is only my own personal experience, of course they may be the only two errors the company has ever made (apart from the on-line sysem you have shown).
Thanks. Think I'll stick with the place I've been using. Bit of a drive but they do a good job
Sent from my SM-G930F using Arbtalk mobile app
