Thinking about a pair of the carbons but unsure about the size thing.
At 6'4" I know I will need the lerge, but does anyone no how 'large' compares to a normal set on max length?
Ta
What spikes are you using at the moment?
I can compare them in the morning for you, you will definitely be a large and you can move the velcro pad up a bit.:001_smile:
Dont laugh but they are some of HB's own about 27 years old :blushing:
(they dont make them like that any more!)
I will measure them fri/sat.
Thanks Justin
no..but if you are over 14 stone..its a bit pointless...
climber wearing feather weight spikes while being 15 stone and 066 hanging from harness. :confused1:
What garbage. Just because you don't weigh 9stone your not allowed lightweight spikes? your going to say you have to be 14 stone before you can hang a 660 of your harness next?
Justin
18.5cm top of shank to bottom of foot plate (20cm to top of leg pad)
Weight - never seen max weight/load advertised on them, if there is then I will be too heavy, if there is not who gives a ........
