We were discussing this at work the other day, spike up a conifer with flipline and main climbing line, clean off brash on the way up.
I was taught to just have the mainline around the tree. If gaffs kick out, I'm sliding down the tree.
Boss was saying he leaves stubs for this reason. I don't like this solution as you then have to cut again on the way down, or worse, groundie has to clean off the chogs.
The other climber was saying how he'd been taught to tie off his main climbline with a running bowline. Seems neat, but now you've got your full weight on prussik / zigzag / hh w/vt designed for a 2 to 1 mechanical advantage, so likely won't work brilliantly either.
Did a search on the forum and saw some suggestions for adding in a figure of eight to descend, but can't really picture how that would work.
Does any of you kind souls have a picture or two of how to set this up?
  • Replies 22
Choke a cambium saver or sling and biner around the stem and run your rope through that so you can descend quick if an accident happens.
You have to move the cambium saver/sling up as you go up the tree though..which is a bit of a pain.
On connies i really doubt you would fall straight down with a rope and prussik round the stem,more likely to twist and catch you on the rough bark imo
Looks difficult to advance - besides, your not going to slip that far with such monster stubs ;)
Lol yeah was just an example of a top anchor point on a pole to allow for quick descent in a 'i need a cuppa' scenario.:001_smile:
You can always spike back down, or improvise & place a munters on a krab below the prussic. Sometimes an over reliance on gadgets can slow the job down & fatigue you. A cambium saver whilst working I understand, but whilst ascending?
Obviously its not for experienced climbers who are confident spiking up with a flipline or lanyard but for a relativley new climber it might help.
