Is there a website I can use for working out the approx volume of wood chip, if I enter the length and diameter at the base of the tree will it work out roughly the taper on the trunk?
Sent using Arbtalk Mobile App
Colwood Land Care, Tree surgery, Sussex
I don't know about a website but it would depend on whether open or forest grown. There are tables for single forest tree volumes.
For a forest tree as a rough Idea you could estimate the height of the main stem and half it.
Take the diameter at 1.5 metres and then allow a 1 in 100 taper to the half height, calculate the volume of stem using the half height and diameter you have calculated at this height. Add 25% for branch wood. Allow about 2.75m3 of chip for every m3 of solid timber.
There is a timber volume calculator here:-
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiX0LWpw4jRAhVrKsAKHZ2EAqsQFggjMAA&url=http%3A%2F%2Fwww.forestry.gov.uk%2Fpdf%2Ftimbervolume.pdf%2F%24FILE%2Ftimbervolume.pdf&usg=AFQjCNEQ3hNhQ7q2eqJ4239qk6syHEjEiQ
Sorry, can't seem to get this as a link, just copy and paste.
You could use this to come up with a fairly accurate estimation of the tree volume, then multiply by 2.6 as mentioned earlier.
