Stump grinder teeth sharpening & re-tipping
inthewoods
Depends on your technique. I find they work OK with a bit of practice and are essential for 13hp machines, little and often! Got a rayco rg20 with greenteeth now and that was still blasting through stumps when dull last week so won't be bothering to sharpen the teeth with a grinder like had to before every stump with my rock machinery one
Sent from my SM-G930F using Arbtalk mobile app
I found those diamond discs pretty ineffective and hard work.
I used a normal disc for the steel & touched up all 12 teeth in about 20 minutes. Doesn't look too pretty but today was only it's second outing, on a stump that was twice the size of the first one & took me about the same time (not including tea, chatting & clearing the area) I got as close to 30 degrees as I could, think I'd get a better finish & longer tooth life with a bench grinder though.
Hia Dan, did you get the price you wanted for your rock grinder? I ended up getting a us praxis!
He yeah. Massive difference! Still can't fault the little machine for what it costs but I've only used the rayco for under 2 hours actual grinding time and that's bought it around £700 so much better money earner
Sweet, mines done about 40 minutes for 200 squid so far... This time next year rodders!
