Any way of setting up a gantry or builder's hoist spanning ditch and walls? Lift stump, run horizontally till over wall, lower. Once you've got that far the rest should be a doddle!
  • Replies 36
at risk of stating the obvious...
can you not just build a fire around the stump ( which has been dug around) and just sit back and drink tea, occasinally topping up fire to make sure stump burns?????
i was thinking that from the start but didnt say anything cus i didnt want to look special :P
Done stump..no pics though as were working so hard!
It had about 60k of concrete attached to it at the bottom / red bricks / and metal poles through it.
No access for crane / fire would have been just stuuupid!
thanks to guy working for me ( sharpened chainsaws about 10 times today ) we managed to cut enough of to roll it over..then about 2 hrs of smashing it with sledge hammer.
Mark Bolams idea of power washer worked best. managed to clean dirt off enough to make some good cuts.
Took about 5 hrs to do..felt bad charging costumer 250 for it...but had to replace chains.
