Stupid or Insurance Claim??
hamdogg
  • Replies 37
All went well obviously, but did you not think about propping/'A' frame before you went up it?
Might have helped with the twitchiness...
Or made it into a big see saw :thumbup: There were some mature white poplars down the local fishing pond that gradually lowered themselves to the ground with the prevailing wind over a number of months.
Perhaps not surprisingly, I had "twitchiness" viewing the photos :001_huh:
Practically how would you have propped/A framed it? I'm familiar with, for instance, ratchet straps being used where stems have split (IRRELEVANT) but cannot envisage "how" you would achieve this?
Thanks in anticipation,
Paul
Paul
You had to make me get MS Paint out again didn't you...
The expertly drawn model is what I had in mind. Either a. A-frame acting as a prop with the red sections as 5T ratchet straps or similar. It is possible to do this with a third upright to the A-frame, thereby making a tipi or triple A-frame. Wedges at the bottom if they can be used depending on the ground.
or b. a set of linear/single props at right angles to the tree in the direction of the lean. These could be nailed/screwed/strapped to the stem. Again, wedged if possible to secure them from movement.
Either way, made with substantial timber eg 4"x4" minimum, but better with 4"x6" or 6"x6".
Turns out not needed in this instance of course, but if the ground was soft and still had plate movement, I would have looked to support it before going out on the stem.
Each to their own though I expect...
Excellent, thank you, I do appreciate your efforts :thumbup1::thumbup1::thumbup1:
Paul
