I got one off eBay that looks exactly the same as the Aldi one. It gives me results I'd expect. Recently felled and freshly split beech around 40% so if I split something seasoned and it says 20% thereabouts i tend to believe it enough. My logs burn lol
Sent from my iPhone using Tapatalk
I have the Burg-Wächter one from Lidl? Aldi?.
This is the only one I've had which doesn't eat batteries.
I had another one from Lidl where I had to take the 9V battery out every time I put it away!
I also cottoned on to not keeping the meter in my pocket (keeps it warm so the temperature compensation gets confused) and not testing a newly split cold log as soon as I've brought it into warm, humid house,:lol:
As long as you use the same meter and have an idea what reading you need for the wood to be be ready to burn, then that should be all you need.
Its been said on here many times but if you need an accurate reading then calibrate your meter with scales and microwave or oven. Mine is mid range quality but strays from the truth with high and low MC.
This . Use as a compareter only .
We've got a few stihls as well, they always seem consistent and read around what I would expect. As others have said nearly anything will work if you're using it to get a comparison rather than an exact reading.
