Augur bits go that size and bigger and are good at pulling the shavings out
Agree - I would auger that size on green logs, but depends on how many you are doing as it could become hard work...
I'd use auger bits for that size hole...
FIL uses a 2 stroke engine powered auger drill for doing similar (or even bigger) holes when repairing the quayside decking etc at Blyth Harbour.....
best to use a hole saw bit without the pilot, drill in how deep you want, then get a chisel and break it out, can then level the bottom out with a really shape chisel. that way u don't end up with a pilot hole like you do with a spade bit. only take it out if u need to though!
i've just got one for making a 90mm hole in some logs!!!
