  • Replies 60
Carabiners have poor off axis strength, a mallion is probably a better choice
Yes, I cant disagree with you!
Giorgio Fiori excellent videos are food for thought though. Have you seen his demo load test on a side loaded alloy crab in a sinch configuration ?
I have not seen Giorgio's I will watch it later, I did read about the destructive testing Tefeulberger did depending on stem diameter and type of carabiners (bar profile v oval/ibeam) failures occurred as low as 4-6kn.
Going back to mallions I have seen this which is an interesting idea.
[ATTACH]218648[/ATTACH]
Simple, failsafe.
It's great and smoother to retrieve than pinto set up imo .:thumbup:
An absolute nut ache to re set if you haven't isolated a final tip. Any easier ways of re setting?
Took me a few minutes to work out how that spanner could be any use when it was already on the mallion :blushing:
Thank God for that! Thought I was on my own for a minute!
That's a cool idea with the spanner left on there.
I use that same delta link with a butterfly and enough tail to retrieve.
May go fun and old spanner to grind down and try this
I got that from JB's Facebook page so credit to him.
